I have a really strange behaviour with Influx Version 2.0.9 and also with 2.1.1.
My InfluxDb is running on Kubernetes as a statefull set. The Folder /root/.influxdbv2 is mounted on a PVC for persistence.
In Kubernetes also only one Pod is running right now.
I can reproduce the following steps every time:
- Setup Influx with an admin user
- Write some Data in it, all is fine
- Delete the Pod, the Pod is then created again
- When Influx is back up and running again, it is in it’s initial state. I have to setup a user again. After I have done this, the data is also gone
- If I check the /root/.influxdbv2 Folder on the new created pod, all the data seams to be there. For example I have 10GB of Data in it.
So to summarize, if I restart/delete my influxdb Pod, the new created Pod behavious like a new naked instance. The data in the folder /root/.influxdbv2 seams to be there.
Is there any other folder I need to persist to prevent that from happening?
Thank you,
Best regards,
Martin
