Hi there,
I’m deployng influxdb on docker (on a Server) using as storage for the data a CIFS share on my Nas.
I get this error:
2024-02-06T13:23:31.518836197Z info booting influxd server in the background {"system": "docker"}
ts=2024-02-06T13:23:31.633544Z lvl=info msg="Welcome to InfluxDB" log_id=0nBeFjhG000 version=v2.7.5 commit=09a9607fd9 build_date=2024-01-05T17:17:04Z log_level=info
ts=2024-02-06T13:23:31.633599Z lvl=warn msg="nats-port argument is deprecated and unused" log_id=0nBeFjhG000
ts=2024-02-06T13:23:31.680445Z lvl=info msg="Resources opened" log_id=0nBeFjhG000 service=bolt path=/var/lib/influxdb2/influxd.bolt
ts=2024-02-06T13:23:31.680598Z lvl=info msg="Resources opened" log_id=0nBeFjhG000 service=sqlite path=/var/lib/influxdb2/influxd.sqlite
ts=2024-02-06T13:23:31.686747Z lvl=info msg="Bringing up metadata migrations" log_id=0nBeFjhG000 service="KV migrations" migration_count=20
ts=2024-02-06T13:23:32.460344Z lvl=info msg="Bringing up metadata migrations" log_id=0nBeFjhG000 service="SQL migrations" migration_count=8
2024-02-06T13:23:32.522061964Z info pinging influxd... {"system": "docker", "ping_attempt": "0"}
2024-02-06T13:23:33.532295259Z info pinging influxd... {"system": "docker", "ping_attempt": "1"}
2024-02-06T13:23:34.542014974Z info pinging influxd... {"system": "docker", "ping_attempt": "2"}
2024-02-06T13:23:35.552218675Z info pinging influxd... {"system": "docker", "ping_attempt": "3"}
2024-02-06T13:23:36.562369653Z info pinging influxd... {"system": "docker", "ping_attempt": "4"}
ts=2024-02-06T13:23:37.472605Z lvl=error msg="Failed to apply SQL migrations" log_id=0nBeFjhG000 error="database is locked"
Error: database is locked
See 'influxd -h' for help
2024-02-06T13:23:37.572233232Z info pinging influxd... {"system": "docker", "ping_attempt": "5"}
/entrypoint.sh: line 284: kill: (101) - No such process
2024-02-06T13:23:37.580782226Z error influxd crashed during startup {"system": "docker", "total_pings": "6"}
2024-02-06T13:23:37.582267348Z warn cleaning bolt and engine files to prevent conflicts on retry {"system": "docker", "bolt_path": "/var/lib/influxdb2/influxd.bolt", "engine_path": "/var/lib/influxdb2/engine"}
"bolt-path": "/var/lib/influxdb2/influxd.bolt",
"engine-path": "/var/lib/influxdb2/engine",
"nats-port": 4222,
"http-bind-address": ":9999"
This is my docker compose file:
version: "3"
services:
influxdb:
container_name: InfluxDb2
image: influxdb:latest
networks:
- influxdb_grafana_net
env_file:
- influxv2.env
volumes:
- influxdb_cifs:/var/lib/influxdb2
#- "/srv/docker/volumes/influxdb:/var/lib/influxdb2:rw"
ports:
- 8086:8086
restart: always
volumes:
influxdb_cifs:
driver_opts:
type: cifs
o: username=influxdb,password=xxxxxx,uid=1000,gid=1000,vers=3.0
device: //192.168.10.26/VM_Storage/InfluxDB
networks:
influxdb_grafana_net:
The container has access to the shared folder because I see this folder inside of network share:
- Engine folder
- influxd.sqlite
If I change the volume to one local volume with
everything works.
Any suggestion how to save the data on my NAS?
Thank you in advance!
