hi everyone, please help… my skills are not the best… i need to install ifluxdb for openhab. unfortunately it doesn’t work as it should… I installed it on debian 11… I don’t even know what information I should put here, I hope that with the tick I’ll post someone will be able to help me what I’m doing wrong… that influxdb doesn’t work
root@debian:/home/marcin# apt-cache policy influxdb2
influxdb2:
Zainstalowana: 2.6.1-1
Kandydująca: 2.6.1-1
Tabela wersji:
*** 2.6.1-1 500
500 https://repos.influxdata.com/debian stable/main amd64 Packages
500 https://repos.influxdata.com/debian bullseye/stable amd64 Packages
100 /var/lib/dpkg/status
2.6.0-1 500
2.5.1-1 500
2.4.0-1 500
2.3.0-1 500
2.2.0 500
root@debian:/home/marcin# sudo systemctl start influxdb
Job for influxdb.service failed because a timeout was exceeded.
See "systemctl status influxdb.service" and "journalctl -xe" for details.
root@debian:/home/marcin# sudo systemctl enable influxdb
Synchronizing state of influxdb.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable influxdb
root@debian:/home/marcin# sudo systemctl status influxdb
● influxdb.service - InfluxDB is an open-source, distributed, time series datab>
Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor pres>
Active: activating (start) since Wed 2023-01-25 22:17:24 CET; 56s ago
Docs: https://docs.influxdata.com/influxdb/
Cntrl PID: 18868 (influxd-systemd)
Tasks: 2 (limit: 4573)
Memory: 1.2M
CPU: 2.246s
CGroup: /system.slice/influxdb.service
├─18868 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-sta>
└─19196 sleep 1
sty 25 22:18:11 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://>
sty 25 22:18:12 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://>
sty 25 22:18:13 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://>
sty 25 22:18:14 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://>
sty 25 22:18:15 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://>
sty 25 22:18:16 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://>
sty 25 22:18:17 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://>
sty 25 22:18:18 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://>
sty 25 22:18:19 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://>
sty 25 22:18:20 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://>
lines 1-22/22 (END)...skipping...
● influxdb.service - InfluxDB is an open-source, distributed, time series database
Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
Memory: 1.2M
CPU: 2.246s
├─18868 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
└─19196 sleep 1
sty 25 22:18:11 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://localhost:8086/ready unavailable after 45 attempts...
sty 25 22:18:12 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://localhost:8086/ready unavailable after 46 attempts...
sty 25 22:18:13 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://localhost:8086/ready unavailable after 47 attempts...
sty 25 22:18:14 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://localhost:8086/ready unavailable after 48 attempts...
sty 25 22:18:15 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://localhost:8086/ready unavailable after 49 attempts...
sty 25 22:18:16 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://localhost:8086/ready unavailable after 50 attempts...
sty 25 22:18:17 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://localhost:8086/ready unavailable after 51 attempts...
sty 25 22:18:18 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://localhost:8086/ready unavailable after 52 attempts...
sty 25 22:18:19 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://localhost:8086/ready unavailable after 53 attempts...
sty 25 22:18:20 debian influxd-systemd-start.sh[18868]: InfluxDB API at http://localhost:8086/ready unavailable after 54 attempts...
lines 1-22/22 (END)
I apologize in advance if you are irritating beginners… but I am asking for help in solving the problem… greetings to everyone
