When Iam starting InfluxDB in a docker-compose szenario the influx logs the following messgages:
influxdb init process in progress…
influxdb init process failed.
Why does the progress fails?
I noticed that the more services I add to the compose file the longer does the init progress needs. When only ading a few services it works.
After 30 “tries”, the init progress failes. I only added the env var INFLUX_DB variable to instantiate a database on startup.
When starting this, the log “influxdb init process in progress…” shows up about 10 times. Now when I add other services like a mongodb or else, the loh shows up more often.
This only happens, when the influx volume does not exists…
Seems to be a bug in the docker variant.
When I do not state the environment variable INFLUXDB_DB and create the database in code, it works fine and the init process is fast.
