Hey @all,
I have an docker InfluxDB v1.8 Instance with data of almost one year. I wanted to migrate the data to another retentionPolicy (to autogen). While migrating the influx crashed because of memory limitations (go error, malloc). Because of this, I manually moved some directories, so the DB could work on less data. With these modifications, the migration worked just fine, but it seems to have corrupted my database.
I can query the old data, but new data is no longer written into the DB. My log looks perfectly normal:
[httpd] 172.19.0.17 - - [05/Sep/2022:09:43:53 +0000] "POST /write?db=MyDB&rp=autogen&precision=n&consistency=one HTTP/1.1 " 204 0 "-" "okhttp/4.10.0" 40a60ac7-2cff-11ed-826d-0242ac130007 6955
But I can’t query the data, or there is none.
Apart form that I can insert more data into unrelated measurements within the same database.
I tried exporting the data into a portable backup and import that into a new DB (fresh docker volume) but it didn’t fix the problem. Also I have checked the tsm files:
influx_inspect verify -dir /var/lib/influxdb
/var/lib/influxdb/data/MyDB/autogen/10/000000027-000000003.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/11/000000020-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/12/000000025-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/13/000000024-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/14/000000015-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/15/000000021-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/16/000000017-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/17/000000015-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/18/000000015-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/19/000000021-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/2/000000033-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/20/000000025-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/21/000000018-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/22/000000022-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/23/000000039-000000003.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/24/000000026-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/25/000000024-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/26/000000017-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/27/000000015-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/28/000000015-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/29/000000013-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/3/000000016-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/30/000000013-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/31/000000020-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/32/000000026-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/33/000000002-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/34/000000002-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/35/000000003-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/36/000000001-000000001.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/4/000000012-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/5/000000033-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/6/000000028-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/7/000000027-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/8/000000027-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/autogen/9/000000033-000000002.tsm: healthy
/var/lib/influxdb/data/MyDB/policy_360d/71/000000001-000000001.tsm: healthy
Broken Blocks: 0 / 122527, in 1.489326344s
I have no idea why I can’t write more data. Can anyone help me narrowing down the problem? I will happily provide more data or logs if needed.
Thanks, Arne
