I installed InfluxDB v.1.7.10 on windows, do I need to take daily backup?
Is there a way to automate the backup procedure daily (like SQL server) and how?
Best regards,
Ganendran
Best regards,
Ganendran
Hello @Ganendran,
You use cron to schedule a influxd backup command
InfluxDB v1.x
With InfluxDB 2
