Influxdb server is on a windows host.
After a stupid mistake, I lost the admin token created the first time.
What file or base registry key can I delete to recover “fresh install” and create a new admin token ?
I don’t care if datas are lost.
Thank’s for your support.
Just delete the binaries that got extracted when you ran the InfluxDB 3 installation/download and re-install and create new token.
Thank you suyash
I have the same problem but this doesn’t work for me. When I reinstall the new binaries and try to create a new admin token it says one still exists. Is this info stored somewhere else that needs to be deleted?
One way is to delete and reinstall influxdb 3. You can also try to regenerate it : Regenerate an admin token | InfluxDB 3 Core Documentation
