Hello and a happy new year!
I am trying to setup influxdb 2.6 using docker.
The instance is running and i can access the influxdb page in my localhost.
But when I try to access the database with javascript it gives me an 401 error, saying that i dont have permission.
This is the js code:
const Influx = require('influx');
const influx = new Influx.InfluxDB({
host: 'localhost',
port: 8086,
database: 'gasometer',
username: 'admin',
password: 'adminsecret',
export const getDatabases = async () => {
console.log(await influx.getDatabaseNames());
I cant pass the api key into the config above, as there is no ‘api’ field showing up for me.
I also heard that one have to customize the config file, but there is no config file for me.
This is my docker code:
docker run -d -p 8086:8086 --name influxdb -v %cd%/data:/var/lib/influxdb -v %cd%/config:/etc/influxdb amd64/influxdb
It creates the config folder but with no content in it.
I also tried to pass the INFLUXD_CONFIG_PATH but it also had no effect.
This was the command for that:
docker run -d -p 8086:8086 --name influxdb -v %cd%/data:/var/lib/influxdb -v %cd%/config:/etc/influxdb -e INFLUXD_CONFIG_PATH=%cd%/config/etc/influxdb amd64/influxdb
Any help is highly appreciated.
Thanks! ![]()
