I need to get container logs into file and mount in local directory. Max N files and file size should be N mb each.
I used below command to get logs in file but it creates single file whose size can grow with time.
command: bash -c "influxd 2>&1 | tee -a /var/log/influxdb/influxdb.log"
I need to restrict file size and number of files created. How do I achieve this using configuration in influxdb ?
Any help appreciated.
BR,
Dhyanesh
