Hi, everyone!
I’ve been having problems for a few days in the influx datadir.
The influx datadir has 106G, dedicated just for it, the folders (data, wal and meta) are all there and I’ve already occupied more than half of it - an abnormal behavior.
After restarting the service, the occupation of the datadir returns to ~20%.
The machine’s resources are ok.
I’ve a VM - CentOS 7, 24vCpus and 30Gb RAM.
I have an Influx v.1.8.4 with 523 measurements and 3 fields (time, id and value) each.
My retention policy:
name duration shardGroupDuration replicaN default
autogen 17544h0m0s 720h0m0s 1 true
Influx_inspect:
influx_inspect verify -dir /var/influxdb/
Broken Blocks: 0 / 38334621, in 56.972801362s
The only error I found was this:
influx_inspect report /var/influxdb/data
report: not a valid shard dir: /var/influxdb/data/flex/autogen/100/1.tmp
I didn’t find references about it.
I think the compression is having problems.
Any suggestion?
Best regards!
