Influxdb 1.6.3 high cpu %usage
I am running influxdb 1.6.3 on my ubuntu 16.04 64 bit, 4 core, 8GB RAM.
i always notice the cpu usage goes to 50%, 80% , 150% for the influxdb process. Because of that some times, load goes to very high and come down to normal. i could not find any error from the log.
can some one let me know how to investigate on this issues? thank you.
I have the same issue. Is influxdb tunable to reduce cpu usage
same issue. any updates??
Hi @Kiddinglife ,
The environment variable GOMAXPROC can be used to set the maximum number of CPUs that can execute simultaneously.
Is this of any help to you ?
best regards
Hi @MarcV
setting GOMAXPROC varialbe, doesnot help as well.
is there any way to findout what causing this issues?
