Influxd fatal error: out of memory
I am using influxdb 1.7.9 version and facing “out of memory” issue while restarting influxd service. Also while running influx command to connect database it is giving “Failed to connect to http://localhost:8086
This is the second time that I encounterred this issue, it has been worked well for more then 1 month.
I did change anything in influxdb.conf. The size of database looks well.
And I found influxd occupied the CPU
Request help on fixing these issues
List of issues:
Aug 23 03:22:40 ip-10-51-72-215 influxd: fatal error: runtime: out of memory
Aug 23 03:22:40 ip-10-51-72-215 systemd: influxdb.service: main process exited, code=exited, status=2/INVALIDARGUMENT
Aug 23 03:22:40 ip-10-51-72-215 influxd: runtime stack:
Aug 23 03:22:40 ip-10-51-72-215 influxd: runtime.throw(0x1539721, 0x16)
Aug 23 03:22:40 ip-10-51-72-215 influxd: /usr/local/go/src/runtime/panic.go:617 +0x72
Aug 23 03:22:40 ip-10-51-72-215 influxd: runtime.sysMap(0xc024000000, 0x4000000, 0x3165998)
Aug 23 03:22:40 ip-10-51-72-215 influxd: /usr/local/go/src/runtime/mem_linux.go:170 +0xc7
Aug 23 03:22:40 ip-10-51-72-215 influxd: runtime.(*mheap).sysAlloc(0x314ca40, 0x2000, 0x314ca50, 0x1)
Did it create a core dump ? (Sometimes under /tmp , othertimes under the default working directory when process launches)
Does this only occur occasionally or does it happen each time you start it?
Are you able to upgrade to latest 1.8.x version?
Thanks for your reply, what do you mean by "core dump ", I just created database, no other configuration. Influxd has been working well for more than 1 month, but now it can’t work even though I restart it again and again. Could you please tell me how to upgrade to 1.8 version safe? Since it can’t work, I can’t backup my database.
Core dumps are a dump of memory at the point a process crashes , here’s a generic page from arch that gives some background - note your distro might save them somewhere else, but a look under /tmp, and /var/lib/systemd/coredump
They are usually named core.12345 where 12345 was the pid number… basically that file is a dump from memory (which it ran out of) and can be analysed what it was full of / doing , at the point it died.
I didn’t see any file under /var/lib/systemd/coredump and /tmp
Could you please help me on this issue? Thank you so much
Unless you are able to find a way to get it to produce a core dump, I don’t have any other ideas right now.
Can you confirm your box’s total memory available, and how much is definitely free (including memory used by buffers/cache)
posted a similar issue on github. Influx seems to do a poor use of resources
