dasel
error message:
Error: cannot use property selector on non map/struct types: invalid: property not found: tls-cert
Error: cannot use property selector on non map/struct types: invalid: property not found: tls-key
/etc/influxdb/config.json
{ "tls-cert": "/tls/cert.pem", "tls-key": "/tls/privkey.pem" }
$ export INFLUXD_CONFIG_PATH=/etc/influxdb/
$ ./entrypoint.sh influxd
Error: could not get read parser: read parser required when reading from stdin
panic: reflect: call of reflect.Value.Set on zero Value
goroutine 1 [running]:
reflect.flag.mustBeAssignableSlow(0xc000132f70?)
/opt/hostedtoolcache/go/1.21.3/x64/src/reflect/value.go:265 +0x105
reflect.flag.mustBeAssignable(...)
/opt/hostedtoolcache/go/1.21.3/x64/src/reflect/value.go:259
reflect.Value.Set({0x0?, 0x0?, 0x7f8a0ccca108?}, {0x771380?, 0xc0001c1820?, 0xc0001c1820?})
/opt/hostedtoolcache/go/1.21.3/x64/src/reflect/value.go:2254 +0x65
github.com/tomwright/dasel/v2.newContextWithFunctions.func1({{0x771380, 0xc0001c1820, 0x16}, 0x0, 0x0, 0x0})
/home/runner/work/dasel/dasel/context.go:62 +0x8c
github.com/tomwright/dasel/v2.Value.Set(...)
/home/runner/work/dasel/dasel/value.go:151
github.com/tomwright/dasel/v2.Value.initEmptydencodingMap({{0x0, 0x0, 0x0}, 0xc000177db0, 0x0, 0x0})
/home/runner/work/dasel/dasel/value.go:325 +0x19a
github.com/tomwright/dasel/v2.Values.initEmptydencodingMaps({0xc00041b110, 0x1, 0xc0002d61c0?})
/home/runner/work/dasel/dasel/value.go:502 +0x167
github.com/tomwright/dasel/v2.glob..func26(0xc00050c400, 0x41567a?, {0xc000177dc0, 0x1, 0xa2b000?})
/home/runner/work/dasel/dasel/func_property.go:38 +0x1d4
github.com/tomwright/dasel/v2.BasicFunction.Run(...)
/home/runner/work/dasel/dasel/func.go:144
github.com/tomwright/dasel/v2.(*Step).execute(0xc000360aa0)
/home/runner/work/dasel/dasel/step.go:30 +0xc3
github.com/tomwright/dasel/v2.(*Context).Next(0xc00050c400)
/home/runner/work/dasel/dasel/context.go:227 +0x1a5
github.com/tomwright/dasel/v2.(*Context).Run(0x78b120?)
/home/runner/work/dasel/dasel/context.go:195 +0x29
github.com/tomwright/dasel/v2.Put({0x78b120, 0xc00041b0b0}, {0x7ffc52460522, 0x11}, {0x72dea0?, 0xc000177da0?})
/home/runner/work/dasel/dasel/context.go:130 +0xf9
github.com/tomwright/dasel/v2/internal/command.runPutCommand(0xc000133c90, 0x790aa1?)
/home/runner/work/dasel/dasel/internal/command/put.go:144 +0x571
github.com/tomwright/dasel/v2/internal/command.putRunE(0xc00028c700?, {0xc000360960, 0x1, 0x78d922?})
/home/runner/work/dasel/dasel/internal/command/put.go:95 +0x613
github.com/spf13/cobra.(*Command).execute(0xc000004600, {0xc000360910, 0x5, 0x5})
/home/runner/go/pkg/mod/github.com/spf13/cobra@v1.7.0/command.go:940 +0x87c
github.com/spf13/cobra.(*Command).ExecuteC(0xc000004300)
/home/runner/go/pkg/mod/github.com/spf13/cobra@v1.7.0/command.go:1068 +0x3a5
github.com/spf13/cobra.(*Command).Execute(0x0?)
/home/runner/go/pkg/mod/github.com/spf13/cobra@v1.7.0/command.go:992 +0x13
main.main()
/home/runner/work/dasel/dasel/cmd/dasel/main.go:10 +0x25
reflect.flag.mustBeAssignableSlow(0xc0001daf78?)
reflect.Value.Set({0x0?, 0x0?, 0x7feabbe2c5b8?}, {0x771380?, 0xc0001f4fe0?, 0xc0001f4fe0?})
github.com/tomwright/dasel/v2.newContextWithFunctions.func1({{0x771380, 0xc0001f4fe0, 0x16}, 0x0, 0x0, 0x0})
github.com/tomwright/dasel/v2.Value.initEmptydencodingMap({{0x0, 0x0, 0x0}, 0xc0000277e0, 0x0, 0x0})
github.com/tomwright/dasel/v2.Values.initEmptydencodingMaps({0xc000375ec0, 0x1, 0xc000138f00?})
github.com/tomwright/dasel/v2.glob..func26(0xc000381280, 0x41567a?, {0xc0000277f0, 0x1, 0xa2b000?})
github.com/tomwright/dasel/v2.(*Step).execute(0xc0003317c0)
github.com/tomwright/dasel/v2.(*Context).Next(0xc000381280)
github.com/tomwright/dasel/v2.Put({0x78b120, 0xc000375e60}, {0x7fff3b571530, 0x8}, {0x72dea0?, 0xd02c20?})
github.com/tomwright/dasel/v2/internal/command.runPutCommand(0xc0001dbc90, 0x790aa1?)
github.com/tomwright/dasel/v2/internal/command.putRunE(0xc0001ae200?, {0xc000331680, 0x1, 0x78d922?})
github.com/spf13/cobra.(*Command).execute(0xc000004600, {0xc000331630, 0x5, 0x5})
main.main()
reflect.flag.mustBeAssignableSlow(0xc0001a6f70?)
reflect.Value.Set({0x0?, 0x0?, 0x7f1881f73108?}, {0x771380?, 0xc0001c1080?, 0xc0001c1080?})
github.com/tomwright/dasel/v2.newContextWithFunctions.func1({{0x771380, 0xc0001c1080, 0x16}, 0x0, 0x0, 0x0})
github.com/tomwright/dasel/v2.Value.initEmptydencodingMap({{0x0, 0x0, 0x0}, 0xc00009de70, 0x0, 0x0})
github.com/tomwright/dasel/v2.Values.initEmptydencodingMaps({0xc0001f79e0, 0x1, 0xc000012f90?})
github.com/tomwright/dasel/v2.glob..func26(0xc00033b200, 0x41567a?, {0xc00009de80, 0x1, 0xa2b000?})
github.com/tomwright/dasel/v2.(*Step).execute(0xc0002eb770)
github.com/tomwright/dasel/v2.(*Context).Next(0xc00033b200)
github.com/tomwright/dasel/v2.Put({0x78b120, 0xc0001f7980}, {0x7ffc69af5531, 0x7}, {0x72dea0?, 0xd02c20?})
github.com/tomwright/dasel/v2/internal/command.runPutCommand(0xc0001a7c90, 0x790aa1?)
github.com/tomwright/dasel/v2/internal/command.putRunE(0xc00017a200?, {0xc0002eb630, 0x1, 0x78d922?})
github.com/spf13/cobra.(*Command).execute(0xc000004600, {0xc0002eb5e0, 0x5, 0x5})
main.main()
2024-04-15T19:12:44.094920192Z warn cleaning bolt and engine files to prevent conflicts on retry {"system": "docker", "bolt_path": "/var/lib/influxdb2/influxd.bolt", "engine_path": "/var/lib/influxdb2/engine"}
return nil, fmt.Errorf("cannot use property selector on non map/struct types: %s: %w", val.Kind().String(), &ErrPropertyNotFound{Property: property})
