from(bucket: "navi-vts")
|> range(start: 2025-02-07T11:14:11.565Z, stop: 2025-02-07T11:14:11.567Z)
|> filter(fn: (r) => r["_measurement"] == "PositionReport")
|>filter(fn: (r) => r["_field"] == "Latitude")
Hello @Younes_Askour,
Here are some possible reasons for slow query response times, do any apply to you?
- High cardinality
- Unoptimized indexing…queries that filter only by
_measurement
and_field
may need to scan a large number of series. Indexing tags can help. - Large dataset/many points–Even though your query range is small, InfluxDB might be scanning a large dataset due to inefficient filtering.
- HW/Backend storage–If ure running InfluxDB on slow disks or a system with high IO latency, queries may take longer.
Can you filter with a tag?
|> filter(fn: (r) => r["MMSI"] == "257595708") // Example of filtering by a tag
reduce scanning with limit?
|> limit(n: 1)
Also:
