Hell All,
I am new to influx and using influx APIs in golang. I want to learn how to call the delete APIs in golang for deleting data in influx db.
Any link/sample programs will be much appreciated.
Hell All,
Hello @teenccu,
Welcome! What version of InfluxDB are you using?
Here are the API docs:
Here’s an example:
package main
import (
"bytes"
"net/http"
func main() {
url := "http://localhost:8086/api/v2/delete?org=example-org&bucket=example-bucket"
var jsonData = []byte(`
"start": "2020-03-01T00:00:00Z",
"stop": "2020-11-14T00:00:00Z",
"predicate": "_measurement=\"example-measurement\" AND exampleTag=\"exampleTagValue\""
req, err := http.NewRequest("POST", url, bytes.NewBuffer(jsonData))
if err != nil {
panic(err)
req.Header.Set("Authorization", "Token YOUR_API_TOKEN")
req.Header.Set("Content-Type", "application/json")
client := &http.Client{}
resp, err := client.Do(req)
if err != nil {
panic(err)
defer resp.Body.Close()
// Handle the response here, e.g., read resp.Body or check resp.StatusCode
Hello Anaisdg,
Thanks for your response. I am using V2. so thanks for providing the example .
For the moment I am using the GoLang APIs for treating the data
import (
influxdb2 “github.com/influxdata/influxdb-client-go/v2”
and I have seen there is a deleteAPI provided like
deleteAPI := client.DeleteAPI()
Is it recommended to use that and any example on these APIs ?
Thanks in advance.
Hello @Anaisdg ,
I tried to see the golang API and relate it with your example and I think I can understand it.
I have not tried it yet as I need to reolve another question as posted in
(Read/Delete data with a specific time in golang)
Thanks for your help.
