Hi there.
I do have a backup of an old installation influxdb v1.8 on raspi, generated with
influxd backup -portable /path
Now I am running a raspi v2.6 installation. Is there a way to integrate the old data in my new system? How can I “import” the files?
Thank you
Fred
Pooh
2
should give you a good guide to migrating your data.
Antony.
Thanks Antony.
I am running a 32bit system raspi with influxDB 1.x
To upgrade I need 64bit which I am already running on my influxDB2 system.
Is there a way not to need a kernel upgrade and influxDB upgrade to get my backup data?
Fred
stif
4
you can try with docker.
stop influxdb on old instance:
sudo systemctl stop influxdb
copy everthing from /var/lib/influxdb to your docker machine and map the old and the new influx data folder as volumes to the docker container:
docker run -p 8086:8086 \
-v "./influxdb-backup:/var/lib/influxdb" \
-v "./influxdb2-data:/var/lib/influxdb2" \
-e DOCKER_INFLUXDB_INIT_MODE=upgrade \
-e DOCKER_INFLUXDB_INIT_USERNAME=my-user \
-e DOCKER_INFLUXDB_INIT_PASSWORD=my-password \
-e DOCKER_INFLUXDB_INIT_ORG=my-org \
-e DOCKER_INFLUXDB_INIT_BUCKET=my-bucket \
influxdb:2.6
On first start the data will be migrated from 1.x to 2.x
See also: Problem backup 1.8 restore 2.6 - #3 by stif
Hey stif!
Good idea to use docker. I had not thought of that.
Thank you very much!
Best regards
Sorry for reviving this old thread. But I’m using docker-compose
Do I need to use these commands every time i’m updating the influx docker container?
influxdb:
container_name: influxdb
ports:
- 8086:8086
volumes:
- /opt/influxdb:/var/lib/influxdb
- /opt/influxdb2:/var/lib/influxdb2
environment:
- DOCKER_INFLUXDB_INIT_MODE=upgrade
- DOCKER_INFLUXDB_INIT_USERNAME=user
- DOCKER_INFLUXDB_INIT_PASSWORD=pass
- DOCKER_INFLUXDB_INIT_ORG=org
- DOCKER_INFLUXDB_INIT_BUCKET=bucket
image: influxdb:2.7
or is it 1 time migrating / updating enough?
If so what would the docker-compose.yml suppose to be then?
