Hi, for some time I’m collecting whole IF-MIB::ifXTable table, but there lots of data which I’m not using, how can I query only:
ifHCInOctets
ifHCOutOctets
current telegraf configuration:
[[inputs.snmp.field]]
name = “hostname”
oid = “SNMPv2-MIB::sysName.0”
is_tag = true
[[inputs.snmp.table]]
oid = “IF-MIB::ifXTable”
inherit_tags = [“hostname”]
index_as_tag = true
[[inputs.snmp.table.field]]
is_tag = true
oid = “IF-MIB::ifDescr”
Hello @Paroles_Paroles,
Maybe try something like:
[[inputs.snmp]]
## Other SNMP input configuration settings...
# Get the hostname for tagging purposes
name = "hostname"
oid = "SNMPv2-MIB::sysName.0"
is_tag = true
# Define a table specifically for ifHCInOctets and ifHCOutOctets
oid = "IF-MIB::ifXTable"
inherit_tags = ["hostname"]
index_as_tag = true
# Specify only the fields you need (ifHCInOctets and ifHCOutOctets)
name = "ifHCInOctets"
oid = "IF-MIB::ifHCInOctets"
# is_tag = false is default and can be omitted
name = "ifHCOutOctets"
oid = "IF-MIB::ifHCOutOctets"
# Include ifDescr as a tag if needed for identification
name = "interface"
oid = "IF-MIB::ifDescr"
is_tag = true
Tried this way, but still in Influx I see all table data
time agent_host host hostname ifAlias ifHCInBroadcastPkts ifHCInMulticastPkts ifHCInOctets ifHCInUcastPkts ifHCOutBroadcastPkts ifHCOutMulticastPkts ifHCOutOctets ifHCOutUcastPkts ifHighSpeed ifInBroadcastPkts ifInMulticastPkts ifName ifOutBroadcastPkts ifOutMulticastPkts index interface
2024-03-12T06:50:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 0 0 0 0 0 0 0 0 0 ether1 0 0 1 ether1
2024-03-12T06:50:00Z 192.168.8.1 ubuntu Chateau LTE defconf 0 0 1679326310 4926515 0 0 28955547370 25426053 0 0 0 bridge 0 0 9 bridge
2024-03-12T06:50:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 24899235463 21231977 0 0 1327085756 4063729 0 0 0 lte1 0 0 8 lte1
2024-03-12T06:50:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 0 0 0 0 0 0 50 0 0 wlan2 0 0 7 wlan2
2024-03-12T06:50:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 0 0 0 0 0 0 50 0 0 wlan1 0 0 6 wlan1
2024-03-12T06:50:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 0 0 0 0 0 0 0 0 0 ether5 0 0 5 ether5
2024-03-12T06:50:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 0 0 0 0 0 0 0 0 0 ether4 0 0 4 ether4
2024-03-12T06:50:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 0 0 0 0 0 0 0 0 0 ether3 0 0 3 ether3
2024-03-12T06:50:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 0 0 0 0 0 0 0 0 0 ether2 0 0 2 ether2
2024-03-12T06:50:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 1748297520 4926515 0 0 29363157325 26644918 0 0 0 5Ghz-Chateau LTE-1 0 0 11 5Ghz-Chateau LTE-1
2024-03-12T06:50:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 0 0 0 0 0 0 0 0 0 2Ghz-Chateau LTE-1 0 0 10 2Ghz-Chateau LTE-1
This worked for me
name = "hostname"
is_tag = true
name = "ifXTable"
index_as_tag = true
name = "interface"
is_tag = true
I kinda have the same problem.
Does this worked for you with this indentation?
Are you only getting ifHCIn/OutOctets and ifDescr column on your measurement? (I’m not)
Regards
With config above I’m getting only such values:
time agent_host host hostname ifHCInOctets ifHCOutOctets index interface
2024-03-12T15:06:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 1 ether1
2024-03-12T15:06:00Z 192.168.8.1 ubuntu Chateau LTE 1681638283 28969884794 9 bridge
2024-03-12T15:06:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 10 2Ghz-Chateau LTE-1
2024-03-12T15:06:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 2 ether2
2024-03-12T15:06:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 6 wlan1
2024-03-12T15:06:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 7 wlan2
2024-03-12T15:06:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 3 ether3
2024-03-12T15:06:00Z 192.168.8.1 ubuntu Chateau LTE 24902843983 1330124522 8 lte1
2024-03-12T15:06:00Z 192.168.8.1 ubuntu Chateau LTE 1750872763 29387926847 11 5Ghz-Chateau LTE-1
2024-03-12T15:06:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 4 ether4
2024-03-12T15:06:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 5 ether5
2024-03-12T15:07:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 4 ether4
2024-03-12T15:07:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 5 ether5
2024-03-12T15:07:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 2 ether2
2024-03-12T15:07:00Z 192.168.8.1 ubuntu Chateau LTE 1681641499 28969910044 9 bridge
2024-03-12T15:07:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 1 ether1
2024-03-12T15:07:00Z 192.168.8.1 ubuntu Chateau LTE 24902850092 1330130326 8 lte1
2024-03-12T15:07:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 3 ether3
2024-03-12T15:07:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 6 wlan1
2024-03-12T15:07:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 10 2Ghz-Chateau LTE-1
2024-03-12T15:07:00Z 192.168.8.1 ubuntu Chateau LTE 1750876399 29387973166 11 5Ghz-Chateau LTE-1
2024-03-12T15:07:00Z 192.168.8.1 ubuntu Chateau LTE 0 0 7 wlan2
