I would like to configure influxdb to use 512MB of memory. Is that even possible? How to do this? What can I do to bring back this memory usage?
I am a bit worried that influxdb seems to be very inefficient in a small environment (at least the default configuration), I would be a ‘mess’ on a larger scale deployment.
There are here lots of unhandled OOM issues:
url Out Of memory when SELECT * FROM LIMIT 1 on 128GB host (Influxdb 1.2.4)
url Memory usage on Low-end hardware
url InfluxDB v1.3.1: how to reduce memory usage? - #3 by Lasse
url Influxdb-1.3.6 fatal error: out of memory - #5 by bayendor
I guess I don’t have that many ops. I have 4 nodes that send data every 10s. And have one grafana dashboard refreshing every 5/10s. So why this huge memory usage?
url: https://docs.influxdata.com/influxdb/v1.5/introduction/installation/
Jun 12 22:07:04 db1 kernel: [10681] 994 10681 5473561 358426 3621 365088 0 influxd
Jun 12 22:07:04 db1 kernel: Out of memory: Kill process 10681 (influxd) score 731 or sacrifice child
Jun 12 22:07:04 db1 kernel: Killed process 10681 (influxd) total-vm:21894244kB, anon-rss:1433704kB, file-rss:0kB, shmem-rss:0kB
mysql 1080 0.0 0.0 113264 4 ? Ss Apr20 0:00 /bin/sh /usr/bin/mysqld_safe --basedir=/usr
postgres 1191 0.0 0.0 193196 64 ? Ss Apr20 0:00 postgres: logger process
postgres 19352 0.0 0.0 252248 612 ? Ss Jun13 0:25 postgres: x x x.x.x.x(53824) idle
postgres 1066 0.0 0.0 236428 624 ? S Apr20 24:55 /usr/pgsql-9.5/bin/postgres -D /var/lib/pgsql/9.5/data
postgres 1453 0.0 0.0 236428 728 ? Ss Apr20 1:17 postgres: writer process
postgres 1454 0.0 0.0 236428 1168 ? Ss Apr20 0:51 postgres: wal writer process
postgres 1455 0.0 0.0 237112 1532 ? Ss Apr20 30:10 postgres: autovacuum launcher process
postgres 1452 0.0 0.1 236428 2084 ? Ss Apr20 0:35 postgres: checkpointer process
postgres 1456 0.0 0.1 198296 2164 ? Ss Apr20 55:46 postgres: stats collector process
root 18063 0.0 0.1 234240 2660 pts/0 S+ 12:18 0:00 mysql -p
mysql 1533 1.7 10.5 1209888 197444 ? Sl Apr20 1374:06 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/plugin --log-error=/var/log/mariadb/mariadb.log --open-files-limit=3072 --pid-file=/var/run/mariadb/mariadb.pid --socket=/var/lib/mysql/mysql.sock
influxdb 15804 63.2 67.6 20140780 1271600 ? Ssl 11:39 49:00 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
