I am replicating the already existing support of influxdb 1.8 in my django website, I am keeping the 1.8 version and adding the 2.0 version too.
chart_query = {
'uptime': {
'influxdb': (
"SELECT MEAN({field_name})*100 AS uptime FROM {key} WHERE "
"time >= '{time}' {end_date} AND content_type = '{content_type}' AND "
"object_id = '{object_id}' GROUP BY time(1d)"
'packet_loss': {
'influxdb': (
"SELECT MEAN(loss) AS packet_loss FROM {key} WHERE "
'rtt': {
'influxdb': (
"SELECT MEAN(rtt_avg) AS RTT_average, MEAN(rtt_max) AS "
"RTT_max, MEAN(rtt_min) AS RTT_min FROM {key} WHERE "
'wifi_clients': {
'influxdb': (
"SELECT COUNT(DISTINCT({field_name})) AS wifi_clients FROM {key} "
"WHERE time >= '{time}' {end_date} AND content_type = '{content_type}' "
"AND object_id = '{object_id}' AND ifname = '{ifname}' "
"GROUP BY time(1d)"
'general_wifi_clients': {
'influxdb': (
"WHERE time >= '{time}' {end_date} {organization_id} {location_id} {floorplan_id} "
"GROUP BY time(1d)"
'traffic': {
'influxdb': (
"SELECT SUM(tx_bytes) / 1000000000 AS upload, "
"SUM(rx_bytes) / 1000000000 AS download FROM {key} "
"GROUP BY time(1d)"
'general_traffic': {
'influxdb': (
"WHERE time >= '{time}' {end_date} {organization_id} {location_id} "
"{floorplan_id} {ifname} "
"GROUP BY time(1d)"
'memory': {
'influxdb': (
"SELECT MEAN(percent_used) AS memory_usage "
"FROM {key} WHERE time >= '{time}' {end_date} AND content_type = '{content_type}' "
"AND object_id = '{object_id}' GROUP BY time(1d)"
'cpu': {
'influxdb': (
"SELECT MEAN(cpu_usage) AS CPU_load FROM {key} WHERE "
'disk': {
'influxdb': (
"SELECT MEAN(used_disk) AS disk_usage FROM {key} WHERE "
'signal_strength': {
'influxdb': (
"SELECT ROUND(MEAN(signal_strength)) AS signal_strength, "
"ROUND(MEAN(signal_power)) AS signal_power FROM {key} WHERE "
'signal_quality': {
'influxdb': (
"SELECT ROUND(MEAN(signal_quality)) AS signal_quality, "
"ROUND(MEAN(snr)) AS signal_to_noise_ratio FROM {key} WHERE "
'access_tech': {
'influxdb': (
"SELECT MODE(access_tech) AS access_tech FROM {key} WHERE "
'bandwidth': {
'influxdb': (
"SELECT MEAN(sent_bps_tcp) / 1000000000 AS TCP, "
"MEAN(sent_bps_udp) / 1000000000 AS UDP FROM {key} WHERE "
"time >= '{time}' AND content_type = '{content_type}' AND "
'transfer': {
'influxdb': (
"SELECT SUM(sent_bytes_tcp) / 1000000000 AS TCP,"
"SUM(sent_bytes_udp) / 1000000000 AS UDP FROM {key} WHERE "
'retransmits': {
'influxdb': (
"SELECT MEAN(retransmits) AS retransmits FROM {key} "
"WHERE time >= '{time}' AND content_type = '{content_type}' "
'jitter': {
'influxdb': (
"SELECT MEAN(jitter) AS jitter FROM {key} "
'datagram': {
'influxdb': (
"SELECT MEAN(lost_packets) AS lost_datagram,"
"MEAN(total_packets) AS total_datagram FROM {key} WHERE "
"time >= '{time}' AND content_type = '{content_type}' "
'datagram_loss': {
'influxdb': (
"SELECT MEAN(lost_percent) AS datagram_loss FROM {key} "
default_chart_query = [
"SELECT {field_name} FROM {key} WHERE time >= '{time}' {end_date}",
" AND content_type = '{content_type}' AND object_id = '{object_id}'",
device_data_query = (
"SELECT data FROM {0}.{1} WHERE pk = '{2}' " "ORDER BY time DESC LIMIT 1"
This is the already existing query file.
I have been successful in writing an example data, but I am unable to understand that how do I write so many queries and fit it in flux_query int the below file:
Can you share an example because I searched a lot for this but didn’t get any such example:
the query_data.py file is:
import influxdb_client
# Configuration for your InfluxDB client
bucket = "myname"
org = "myname"
token = "something=="
url = "http://localhost:9086"
client = influxdb_client.InfluxDBClient(
url=url,
token=token,
org=org
query_api = client.query_api()
def execute_query(flux_query):
print("Executing Query:", flux_query)
result = query_api.query(org=org, query=flux_query)
results = []
for table in result:
for record in table.records:
results.append((record.get_field(), record.get_value()))
return results
# Simple uptime query
flux_query = f'''
from(bucket: "{bucket}")
|> range(start: -1d)
# Execute and print results
results = execute_query(flux_query)
print("Results for simple uptime query:", results)
I want all the above queries to be written under “flux_query” here : flux_query = f’‘’
from(bucket: “{bucket}”)
|> range(start: -1d)
How can I achieve this, so that I am able to write all the queries after converting them from influxql to flux?
Sharing my write_data.py too:
from influxdb_client.client.write_api import SYNCHRONOUS
bucket = "mybucket"
org = "myorg"
url=url,
token=token,
org=org
write_api = client.write_api(write_options=SYNCHRONOUS)
p = influxdb_client.Point("my_measurement").tag("location", "Prague").field("temperature", 25.3)
try:
write_api.write(bucket=bucket, org=org, record=p)
print("Data written successfully.")
except Exception as e:
print(f"Failed to write data: {e}")
client.close()
