I’ve read number of posts about high memory usage, and tried some tweaks, but still I am stunned what my tiny instance can do
I run small InfluxDB 1.7.x at home setup, collecting data from sensors. My traffic is at most 2 requests per minute. It was running fine for couple of months and I did not monitor the instance carefully. The hardware is SOHO hp server with 8GB RAM and 1,4GHz AMD CPU. It is running Influx in container along with couple of other services.
Couple of days ago I noticed my services are not responding. The server was almost grind to halt, and Influx ate all memory available. I tried to put some limits (2GB RAM), but situation re-appeared. I managed to get docker stats:
CONTAINER ID NAME CPU % MEM USAGE / LIMIT MEM % NET I/O BLOCK I/O PIDS
568b18738b8e influxdb 8.44% 1.758GiB / 2GiB 87.88% 6.6MB / 7.06MB 125GB / 0B 13
Machine was heavily overloaded:
# uptime
02:31:49 up 5 days, 3:12, 1 user, load average: 918.23, 918.27, 918.12
Influx process was in the D state so it couldn’t be killed. I resorted to restarting whole machine.
And I wonder how come it used so much memory and so many gigabytes of I/O, while my data set is orders of magnitudes smaller.
I tried to upgrade to 1.8.x, looks better:
568b18738b8e influxdb 0.31% 176.4MiB / 2GiB 8.61% 45kB / 28.9kB 61.9MB / 0B 10
but I think the I had to do reboot once again.
Is there any _internal metric worth looking? HeapInUse for example?
