Hello Forum
I’m running an InfluxDB 1.8.9 OSS in a Docker container on an SYNOLOGY DS1522+ NAS using DSM 7.1.
I found very high disk write rates of abt. 2MBytes/s when inserting measurements with two tags and one value.
I’m using the “influxdb out” node in Node-RED v2.2.3 to write with a rate of about 5 measurements per second.
Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd
sata2 141.00 0.00 2325.00 0.00 0 2325 0
Logging ist turned off via
- INFLUXDB_REPORTING_DISABLED = true
- INFLUXDB_HTTP_LOG_ENABLED = false
- INFLUXDB_QUERY_LOG_ENABLED = false
And I’ve set INFLUXDB_DATA_WAL_FSYNC_DELAY to 1s
Any ideas what I’m doing wrong and how I can reduce disk io?
Thanks in advance
Dietmar
Hello @DietmarK,
Thats very odd. How many points are in each measurement?
@Anaisdg
Thanks for coming back to my question!
Sorry, I’m not quite up to speed with the terms - exactly one “datapoint” is always inserted. The measurement has two numerical tags and the numerical measurement value.
The conf file is more or less empty:
[meta]
dir = "/var/lib/influxdb/meta"
[data]
dir = "/var/lib/influxdb/data"
engine = "tsm1"
wal-dir = "/var/lib/influxdb/wal"
Did I miss something important?
//Dietmar
is it possible that these setting can cause this high workload on each insert?
CREATE RETENTION POLICY "rp_1w" ON "high_volume" DURATION 1w REPLICATION 1 DEFAULT
CREATE RETENTION POLICY "rp_forever" ON "high_volume" DURATION INF REPLICATION 1
CREATE CONTINUOUS QUERY "cq_5min" ON "high_volume" BEGIN SELECT mean(value) AS mean_value, max(value) AS max_value, min(value) AS min_value INTO "high_volume"."rp_forever"."sensors" FROM "high_volume"."rp_1w"."sensors" GROUP BY time(5m), * END
//Dietmar
Hm, I’ve removed the CQ and still same load - any more ideas?
It is getting more strange - on a RaspberryPi docker image with InfluxDB 1.8.4 with the same settings and influxdb.conf I get IO rates with 50kBytes/s
HELP!!!
