How to work with the data from the netflow Telegraf plugin?
The netflow plugin for Telegraf creates data like this:
netflow,source=127.0.0.1,version=IPFIX protocol="tcp",vlan_src=0u,src_tos="0x00",flow_end_ms=1666345513807u,src="192.168.119.100",dst="44.233.90.52",src_port=51008u,total_bytes_exported=0u,flow_end_reason="end of flow",flow_start_ms=1666345513807u,in_total_bytes=52u,in_total_packets=1u,dst_port=443u
netflow,source=127.0.0.1,version=IPFIX src_tos="0x00",src_port=54330u,rev_total_bytes_exported=0u,last_switched=9u,vlan_src=0u,flow_start_ms=1666345513807u,in_total_packets=1u,flow_end_reason="end of flow",flow_end_ms=1666345513816u,in_total_bytes=40u,dst_port=443u,src="192.168.119.100",dst="104.17.240.92",total_bytes_exported=0u,protocol="tcp"
netflow,source=127.0.0.1,version=IPFIX flow_start_ms=1666345513807u,flow_end_ms=1666345513977u,src="192.168.119.100",dst_port=443u,total_bytes_exported=0u,last_switched=170u,src_tos="0x00",in_total_bytes=40u,dst="44.233.90.52",src_port=51024u,protocol="tcp",flow_end_reason="end of flow",in_total_packets=1u,rev_total_bytes_exported=0u,vlan_src=0u
netflow,source=127.0.0.1,version=IPFIX src_port=58246u,total_bytes_exported=1u,flow_start_ms=1666345513806u,flow_end_ms=1666345513806u,in_total_bytes=156u,src="192.168.119.100",rev_total_bytes_exported=0u,last_switched=0u,flow_end_reason="forced end",dst="192.168.119.17",dst_port=53u,protocol="udp",in_total_packets=2u,vlan_src=0u,src_tos="0x00"
netflow,source=127.0.0.1,version=IPFIX protocol="udp",vlan_src=0u,src_port=58879u,dst_port=53u,flow_end_ms=1666345513832u,src_tos="0x00",src="192.168.119.100",total_bytes_exported=1u,rev_total_bytes_exported=0u,flow_end_reason="forced end",last_switched=33u,in_total_bytes=221u,in_total_packets=2u,flow_start_ms=1666345513799u,dst="192.168.119.17"
Note that almost all values are fields, not tags.
How do I work with this data using Flux?
As an example, I’d like to know the sum of in_total_bytes per src_port.
Hello @AndreKR,
I apologize for the delay.
If you want to calculate the in_total_bytes per src_port you can do the following:
It would look like something like:
from(bucket: "your_bucket_name")
  |> range(start: -1h) // Adjust the time range as needed
  |> filter(fn: (r) => r._measurement == "your_measurement_name")
  // Optionally, filter by specific fields
  |> filter(fn: (r) => r._field == "in_total_bytes")
  |> schema.fieldsAsCols()
  // Group by the desired field
  |> group(columns: ["src_port"])
  // Sum the values in the field of interest
  |> sum(column: "in_total_bytes")
