How to use syntax highlighting for Flux in Notepad++?
I prefer to edit the queries in Notepad++ because in Grafana there’s very little space.
However, Notepad++ has no syntax highlighter for “Flux”.
Has anyone made a syntax highlighter for Flux? if it’s for a different free editor it’s fine as well.
Or, what’s the closest syntax I can select to get some useful highlighting?
I think your best best would be to use AI tool like ChatGPT or Claude.
That’s a good idea. Here it is, generated with ChatGPT o3 and very briefly tested:
flux.xml.gz (1.5 KB)
