In my downsampling job I want to use offset that takes data from interval from: now() -11m, to: now() - 1m, but when I try to running the query below I get the following error:
“Failed to run task: failed to force run: error exhausting result iterator: type error @4:18-4:43: duration is not Addable”
Query:
option task = {name: "Downsampling", every: 10m, offset: 1m}
data = from(bucket: "my_bucket")
|> range(start: -(task.every + task.offset), stop: -task.offset)
... rest of the query
What is the proper way to use offset in flux if I cannot add durations?
NOTE:
I asked this question before, but it was unclear and I cannot edit it anymore, so I added a new one.
Thank you very much for your answer, but your solution does not work. I get an error:
expected time but found duration (argument to)
But based on this influx documentation:
offset delays execution of actual task and all times are relative to now() - offset, so I don’t have to subtract task.offset, it is already done and tests that I have run confirm that .
