How to upgrade from 1.7.6 to 1.7.8?
Hello @nmahesh567,
Thanks for your question. How are you running Influx currently?
It is a single node.
If you installed InfluxDB from the binary, you can replace the binary with the newer version. If you installed from a package manager like brew or apt-get, you can upgrade using those.
