I can’t seem to figure out how to take my simple Arduino Sketch that monitors data on 1 analog pin and send that info to my influxdb database.
I’m using I believe influxdb version 1.8…
I found on the influxdb website give me example code to send info to the database I’m not sure where I need to add my existing code…
My Existing code:
#include "EmonLib.h"
// Include Emon Library
EnergyMonitor emon1;
// Create an instance
void setup()
Serial.begin(9600);
emon1.current(0, 111.1); // Current: input pin, calibration.
void loop()
double Irms = emon1.calcIrms(1480); // Calculate Irms only
Serial.print(Irms*230.0); // Apparent power
Serial.print(" ");
Serial.println(Irms); // Irms
Any help would be appreciated
