I have created a new parser and would like to run unit test just to make sure that everything works before submitting the pull request.
Could someone suggest here, how can i run unit test.
Thanks in advance.
Br, Aqs.
Thanks in advance.
Br, Aqs.
Hello @Aqs_Younas,
Thank you for your question. First, I suggest looking at other parser test examples and model your test after one of them.
Next, after you’ve compiled with make telegraf, you can just run make test to run your test.
I hope this helps and thanks for contributing!
