Hi
I am new to TICK. I am trying to pass in list of values in batch query kapacitor. It is giving me the following error
*invalid TICKscript: Failed to handle left node: Failed to handle right node: Given node type is not valid evaluation node: ast.ListNode
See the below script:
var ns1 = ['value1', 'value2', 'value3']
var data_norm = batch
|query('SELECT "value" FROM "test"."default"."cpu_usage_rate" where name=\'' + ns1 + '\'
.groupBy('name')
.period(5m)
.every(1m)
|log()
.level('DEBUG')
|mean('value')
.as('cpu_avg')
|window()
.period(15m)
|log()
.level('DEBUG')
|alert()
.warn(lambda: "cpu_avg" < 50)
.crit(lambda: "cpu_avg" < 70)
// Whenever we get an alert write it to a file.
.log('/tmp/alerts.log')
.id('{{ .Name }}')
.id('{{ index .Tags "name" }}')
.message('*Cpu Alerts:* {{ .ID }} has {{ .Level }}
value: *{{ index .Fields "value" }}*
name: *{{ index .Tags "name" }}*
.slack()
.channel('#test')```
I know that i can pass in multiple values to the query using **OR** to the where clause. Is there a way I can use list in the tick script or in the query?
TIA
