thanks for your valuable reply, is there any conditional support here like if elseif else kind of thing,because i am getting mutiple types of logs from same source file and the values inside log are not fixed means the positions of values are not fixed for example
[M1,V4.1.9,0822284F,537272.063,499854.906,121809.109,
0.930,11770.710,6786.713,26.398,50.073,187234.688,
176989.594,23256.539,0.945,11725.495,6798.036,
27.542,164736.391,152346.094,41038.895,0.925,11782.277,
6759.561,24.371,185578.172,170519.484,57513.629,0.919,
11804.357,6802.546,27.281,2540343840.000,2432279360.000,
526516192.000,-1170295.375,0,0,0,0,0,0,0,19/02/03,23:52:17]
[M2,V4.1.8,0833174F,0,0,0,1107617.250,0,0,19/02/03,23:58:41]
[M10,1885517F,0,0,0,0,0,0,18.817,19/02/04,00:00:11]
[M14,v4.5.3,9397282F,17.155,6.900,4.726,5.527,
-90.457,-30.303,-30.706,-29.450,-0.185,-0.221,
-0.151,-0.183,91.901,30.931,31.027,29.970,0,421.129
,418.544,421.021,242.621,243.263,242.224,242.377,0,
127.739,128.246,123.559,50.069,5412456.000,7057992.000
,91584.000,2396025.250,0,0,0,0,0,0,0,0,4.288,0,0,0,0,0,0,0,0,0,1549239797]
[M19,GV4.8.2,4205577F,1308582.000,-623884.188,638114.375,46583.328,38661.109,-343905.688,-366844.188,749411.000,-0.999,
-0.876,0.867,-0.062,1309153.000,712392.188,736046.625,750857.375,437.104,436.600,437.758,436.955,252.388,253.133
,252.109,251.921,2908.599,2823.226,2921.755,2980.815,50.076,4480122880.000,4480352320.000,16744643.000
,-14671176.000,0,0,0,0,1.000,8823884.000,0,0,176.197,5.276,4.354,5.362,2.964,2.855,2.707,1297101.375,0
,1449575.500,19/02/03,23:55:52]
2019-02-03 23:59:02,939 | [S1,V4,0360520F,INVALID DATAMAINS_SUPPLY,25982]
2019-02-03 23:58:11,544 | [S1,OTA,V1.4,7172877F,SOFT RESET,9273]
[V2,7365462F,339.50156, 0.34368,987.82996,456.14764,310.89011,287.22711,416.81348,423.88892,412.90961,413.64191,240.81787,242.50154,243.31425,236.63782, 1.64484, 2.01518, 1.50014, 1.41919,50.08651,206997568.00000]
[V4,9449478F,16358.686,5813.755,-5231.535,-5313.388,0,0,0,0,-0.997,0.810,0.941,
0.827,16409.059,7178.353,5561.770,6422.307,410.950,411.008,412.751,409.092,237.264,236.027,238.177,
237.586,31.704,35.247,29.400,30.466,50.025,20354322.000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,19/02/03,23:51:35]
2019-02-03 23:53:19,765 |
{8569904F,25460.49023, 0.49105,161.10310,107.31907,50.10833,7921411840.00000}
2019-02-03 23:52:33,259 |
0639719F,V4, INVALID DATA,19/02/03,23:52:22
2019-02-03 23:55:45,932 | 0639719F,V4, SOFT RESET,14525
2019-02-03 23:52:11,950 | {“MACID”:“8550815F”,“ID”:“1”,“SS”:“16”,“FW”:“V5.1.11”,“TSRC”:“R”,“SN”:“29370”,“PCK”:{“M28”:“AQPI6H9GvTkpRnbaJ8aO9Pm/JTnoQ9QPU0N18aZCBEurQkhsdkYU+jJFwDq0xd9sQ78m6xhD0v+hQ3QWqEIbljNF5V16RaoOfcWX9xW/PfNsQ9Pm/UNz+W9B8Ca6Re0apkWBH2vFxV2BvwvPM0PVR1pDdoMlQfbR5k9WhEJPVGdYTF7Ras0jAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAH/1kkB/7/pAAAAAAAAAE0o9AEDGC2nP+tVrz/12WA/3sAAxHnAAMR5wADEeXylfp1cV6T4”},“RTC”:“19/02/03,23:51:57”}
-----------------------------------------------------------------------------------------------------------------------above all are the log types that i am getting from same source file and i wanted to parse these logs by fieldwise,but the issue is values (like “MACID”:“8550815F,0639719F,etc) are not in fixed positions in log.
my use case is i want to parse the logs in such way that i should be able to apply aggregation on every field if not possible particular fields like macid which is comming in all types of logs value ending with F like 8569904F,0639719F,8569904F…etc similary for other values.
please help me with this.thanks in advance.
