As I did not make much progress, I moved over to work on a created data set instead of live data to hopefully get a better feel what is a good and what is a less good approach.
With a small script, I’m creating three CSV files which I influx write into their own buckets. “Schema” is like
# hostinfo.csv
#datatype measurement,tag,double,dateTime:RFC3339
m,host,total,time
# hostdata.csv
'm,host,percent,time
# allinone.csv
#datatype measurement,tag,tag,double,dateTime:RFC3339
m,host,totalcpus,percent,time
The goal for this exercise is to find hosts which have a high percent relative to the number of cores a system has. The first two CSV files separate this information into two buckets, one for direct/fast measurements (all 15s) and one with almost static host information (3600s). The third CSV file would inject the total number of cores into each measurement.
The script generates one day of data for about 100 hosts and one measurement per core this host has at that time. This results in CSV files with 27011292 lines (hostinfo 2351 lines) each, with a total size of about 1.2 GByte (hostinfo 100kByte) each.
Ingesting this into Influxdb takes some time, then I ran these fluxes
import "interpolate"
start = 2023-01-01T00:00:00Z
stop = 2023-01-02T00:00:00Z
every = 5m
total = from(bucket: "test_hostinfo")
|> range(start: start, stop: stop)
|> drop(columns: ["_field", "_measurement", "_start", "_stop"])
|> interpolate.linear(every: every)
data = from(bucket: "test_hostdata")
//|> drop(columns: ["_field"])
|> aggregateWindow(every: every, fn:mean)
|> group(columns: ["_time", "host"])
|> sum()
|> group(columns: ["host"])
join(tables: {t1:data, t2:total}, on: ["_time", "host"])
|> map(fn: (r) => ({r with _value: r._value_t1/r._value_t2}))
|> drop(columns: ["_value_t1", "_value_t2"])
This runs for about 56s (wall clock without profiler, profiler rundown below[1]) and due to using interpolate creates some funky results when the underlying hostinfo changes. The other flux
every = 5m
from(bucket: "test_allinone")
|> group(columns: ["_time", "host", "totalcpus"])
|> sum()
|> filter(fn: (r) => exists r._value)
|> map(fn: (r) => ({r with _value: r._value / float(v: r.totalcpus)}))
does not have the the spurious interpolation issues, which is good, but is also slow!
It finishes after more than 80s (profiles output see [2]) and I do not know whether it is a good idea to push a lot of static tag data into each measurement as this will increase bucket size and probably also negatively influence query speed.
Thus bottom line question, what do I need to do, to scale this up to still have “snappy” query times, i.e. less than a minute, with 30 times as many hosts and a time frame of a couple of days. I.e. the underlying data relevant just for this type of query would increase by a factor of about 100. In reality, a lot of extra stuff would be in the bucket alongside this, e.g. cpu-user, cpu-idle, cpu-iowait, …
Is there a way or is this a futile effort?
Thanks a bunch in advance and sorry for the post’s lenght.
[1] Profiler 1 (using awk script to convert nanoseconds to full seconds)
*influxdb.readFilterSource 0.080916
*influxdb.readWindowAgg... 40.105304
*universe.groupTransfor... 36.026369
*execute.simpleAggregat... 18.514951
*universe.groupTransfor... 0.110498
*universe.schemaMutatio... 0.001165
*interpolate.interpolat... 0.030931
*universe.mergeJoinTran... 1.934977
*universe.mergeJoinTran... 0.006108
*universe.mapTransforma... 0.005281
*universe.schemaMutatio... 0.000652
[2] Profiler 2:
*influxdb.readWindowAggregateSource 1.712701
*universe.schemaMutationTransfor... 0.104278
*universe.groupTransformationAda... 51.089083
*execute.simpleAggregateTransfor... 26.305873
*universe.filterTransformation 0.866736
*universe.groupTransformationAda... 0.093152
*universe.mapTransformation 1.394154
*universe.filterTransformation 0.282817
