How to know which database is having more read and writes happening
Hello @vi1421,
Have you seen:
Take a look and let me know if it’s helpful.
As an aside the following could also be useful in the future:
@Anaisdg I don’t think this is useful for us, we are using the version
Branch Build Time Commit Version
1.6 389de31c961831de0a9f4172173337d4a6193909 1.6.3
That version is very old now. If you haven’t started planning an upgrade or parallel build of a new server running 2.x version I would courage you to do so.
@FixTestRepeat Yes, We are planning an upgrade soon.
Is there a way to identify which DB and measurement are getting more read/write for this influxdb version ?
Hm, it’s one of the risks of leaving something in place without upgrading for so long.
Have a look at the page below.
Show stats may help
And the /metrics endpoint - although this might not exist in 1.6.x
@FixTestRepeat Thanks, I will take a look
