Hi everyone,
I’m facing an issue while migrating from InfluxQL to InfluxDB SQL (Cloud v3). Here’s the situation:
In my database, I have a tag mytag that might not exist yet because no data has been inserted with this tag. In the past, with InfluxQL, I could run queries like the following without any issues, even if the tag didn’t exist:
SELECT * FROM my_table WHERE mytag = 'myvalue'
However, in InfluxDB SQL, referencing a non-existent column/tag raises an exception, making it impossible to create queries that conditionally reference this tag.
My Context:
- I’m using Grafana to visualize the data.
- I don’t want to “pollute” my data by pre-inserting a placeholder value for
mytagjust to make the column exist in the schema.
Is there any way to write queries in InfluxDB SQL that gracefully handle nonexistent columns/tags? Ideally, I’d like to create a Grafana dashboard that doesn’t break if the column doesn’t yet exist in the data.
I’d appreciate any insights or alternative solutions!
Thanks in advance! ![]()
