how to get several hostIP result
regex parse error: {192.168.3.189,192.168.0.83} error: repetition operator missing expression
Hello @yoursaaron,
If you want to include all of your host ip simply remove that host_ip filter.
If you want to limit to a specific range of ip you can do:
r.host_ip =~ /192.168.[0-3]$/
For example.
host_ip is diverse and has no fixed format.Not only start with 192.168.
