“SHOW SERIES FROM measurement_name” can show all the series.If the count of series is over 60,000,the browser is slow.So,I only know the count of series from measurement.
If you use Grafana you can use a query like this
SELECT mean(“numSeries”) FROM “_internal”.“monitor”.“database” WHERE (“database” =~ /^$Databases$/) AND $timeFilter GROUP BY time($__interval) fill(null)
You could change the database part to a hard typed value or if you have multiple DB’s then you could use a Grafana template variable.
You would find that specific piece of info from the database measurement.
Hope that helps
PS: you don’t need grafana, it’s just what i use. You could access the same information using Chronograf
Phil
