Hi, I’m doing a dashboard in Grafana to monitor the internals of InfluxDB.
I want a graph showing the total number of series.
I use Telegraf to obtain internal metrics from InfluxDB, so I have measurement “influxdb_database” with “numSeries” value and a tag for “databases”.
Each 10s it sends one insert for each database with the number of series for that particular one.
First I made a “Singlestat”, showing just the sum of all databases for the last data:
SELECT sum(numSeries) FROM "influxdb_database" WHERE time > now() - 15s GROUP BY time(5s) fill(none)
As I know metrics are coming each 10s, looking in 15s windows I will obtain just one “set” of metrics (just once for each database).
Then I made groups each 5s, sum all of them and discard null values (with fill none).
This works but I think is a little bit ugly, and, maybe, if the inserts are not received in the same “instant” sometimes the query return erroneous values.
To graph this my only idea is to group by periods of 10s, but it returns too many points for a timespan of 30d (259k points):
SELECT sum("numSeries") AS "numSeries" FROM "influxdb_database" AND time > now() - 30d GROUP BY time(10s) fill(null)
And, like before, if the inserts don’t come in the same “instant” the value could be miscalculated.
Generalizing the question, if we have 10 databases and we receive the metrics dispersed in 10s slots, how could be done to sum just the last of each one?
If we take a 10s window, you could be missing one metric or taking it two times (supposing they could have some jitter).
Thanks!
