Hi.
Migrating from version 1 to version 2.
Java Application(influxdb-client-java:6.9.0 in use)
There is data.
memory 136.30.13.121 2023-06-27T04:24:14.937000000Z 10
memory 136.30.13.121 2023-06-27T04:25:14.937000000Z 20
memory 136.30.13.121 2023-06-27T04:26:14.937000000Z 30
_measurement:string ipAddr:string _time:time _value:float
memory 160.115.110.222 2023-06-27T04:24:14.937000000Z 100
memory 160.115.110.222 2023-06-27T04:25:14.937000000Z 200
memory 160.115.110.222 2023-06-27T04:26:14.937000000Z 300
I want to get a minimum/maximum value regardless of IP.
The desired data shape is as follows.
_measurement:string max:float min:float
memory 300 10
In version 1.x, it was used as below.
select min(usedPercent) as min, max(usedPercent) as max from memory where ipAddr =~ /(136.30.13.121|160.115.110.222)$/
Adapting to version 2, but not easy.
Thank you.
