How to get list of names of all measurements from InfluxDB cloud in python?
Hi, I have initiated the connection to influxdb cloud with the following python codes :-
import influxdb_client
bucket = "<my-bucket>"
org = "<my-org>"
token = "<my-token>"
# Store the URL of your InfluxDB instance
url="https://us-west-2-1.aws.cloud2.influxdata.com"
client = influxdb_client.InfluxDBClient(url=url, token=token,  org=org)
For the codes to list out all measurements, I found the following codes but Pycharm compiler complained that ‘influxdata/influxdb/schema’ is not found. Please help me. Thanks.
schema.measurements(bucket: "example-bucket")
Yes, because this is no valid python code… no idea where you got this code snippet from…
@bednar any thoughts on this? Thank you
Hi @Anaisdg, @lyhooi
the following code snippet will be work:
from influxdb_client import InfluxDBClient
Configure credentials
influx_cloud_url = 'https://us-west-2-1.aws.cloud2.influxdata.com'
influx_cloud_token = 'my-token'
bucket = 'my-bucket'
org = 'my-org'
client = InfluxDBClient(url=influx_cloud_url, token=influx_cloud_token)
Query to all measurements
query = f"""
import \"influxdata/influxdb/schema\"
schema.measurements(bucket: \"{bucket}\")
print(f'Query: \n {query}')
query_api = client.query_api()
tables = query_api.query(query=query, org=org)
# Flatten output tables into list of measurements
measurements = [row.values["_value"] for table in tables for row in table]
print('Measurements: ')
print()
print(measurements)
client.close()
Regards
Do you know if it’s a way to get the tag values in a range of time (from_time to_time)?
