I’m currently working on influxdb in Python.
When client.get_list_measurements () is executed, an error occurs and the list cannot be acquired.
I think the command is correct in the documentation, but why?
API Documentation — InfluxDB 5.3.1 documentation?
highlight=get_list_measurements#influxdb.InfluxDBClient.get_list_measurements
In addition, client.get_list_database() works fine and you can get the database list.
≪error≫
InfluxDBClientError Traceback (most recent call last)
in
----> 1 dbs = client.get_list_measurements()
c:\users\ot95992\appdata\local\programs\python\python37\lib\site-packages\influxdb\client.py in get_list_measurements(self)
763 {u’name’: u’measurements3’}]
764 “”"
→ 765 return list(self.query(“SHOW MEASUREMENTS”).get_points())
766
767 def drop_measurement(self, measurement):
c:\users\ot95992\appdata\local\programs\python\python37\lib\site-packages\influxdb_dataframe_client.py in query(self, query, params, bind_params, epoch, expected_response_code, database, raise_errors, chunked, chunk_size, method, dropna)
192 method=method,
193 chunk_size=chunk_size)
→ 194 results = super(DataFrameClient, self).query(query, **query_args)
195 if query.strip().upper().startswith(“SELECT”):
196 if len(results) > 0:
c:\users\ot95992\appdata\local\programs\python\python37\lib\site-packages\influxdb\client.py in query(self, query, params, bind_params, epoch, expected_response_code, database, raise_errors, chunked, chunk_size, method)
528 ResultSet(result, raise_errors=raise_errors)
529 for result
→ 530 in data.get(‘results’, )
531 ]
532
c:\users\ot95992\appdata\local\programs\python\python37\lib\site-packages\influxdb\client.py in (.0)
527 results = [
→ 529 for result
531 ]
c:\users\ot95992\appdata\local\programs\python\python37\lib\site-packages\influxdb\resultset.py in init(self, series, raise_errors)
23
24 if self.error is not None and raise_errors is True:
—> 25 raise InfluxDBClientError(self.error)
26
27 @property
InfluxDBClientError: database name required
≪Execution code≫
import influxdb
import pandas as pd
HOST = “localhost”
PORT = 8086
client = influxdb.DataFrameClient(host=HOST, port = PORT)
print(client)
db=client.get_list_database()
print(db)
me = client.get_list_measurements()
print(me)
≪environment≫
Python==3.7.3
influxdb==5.3.0(Python Library)
influxdb v1.8.1
