I am storing lighthouse-data. Each lighthouse-run is a measuring_point and belongs to a measurement. Each measurement has its own unique uuid.
So the structure does look like this:
- site
- measurement
- measurement_point
- measurement_point
- measurement_point
- measurement
- measurement_point
- measurement_point
- measurement_point
- measurement
- site
- measurement
- measurement_point
- measurement_point
- measurement_point
- measurement
- measurement_point
- measurement_point
- measurement_point
- measurement
For each measurement_point I am getting the mean()-value like this:
from(bucket: "test")
|> filter(fn: (r) => r["_measurement"] == "lighthouse")
|> filter(fn: (r) => r["_field"] == "speedindex")
|> filter(fn: (r) => r["site"] == "1d1a13a3-bb07-3447-a3b7-d8ffcae74045")
|> group(columns: ["measurement"])
|> mean()
|> yield(name: "mean")
Now I saw that if I do that, the records ore “losing” their _time, which leads to this graph:
As you can see: Although the measurements have not been performed at the same time, the values are “stacked” at the same time.
If I render a simple table, I am getting this result: Edit: Need to save this in a new post, as I am a new user so I am not allowed to embed multiple images.
This is fine, but I guess it shows the problem: The mean() value is calculated but there is no thing as a “mean time”. And even if I choose median, which should pick the median value (which would have a time, I guess) the _time-value is missing.
What can I do to get the time back?
