Hi all
I’m trying to connect from my local machine to influxdb on the host server using python.
However, I can’t make a connection and get error messages.
This is the code what I tried to connect to.(I’ve changed a http port because another service already used that port)
client = InfluxDBClient(host=‘10.x.x.x’, port=7086, username=‘user of host server’, password=‘p/w of host server’, database=‘test_hd’)
client.ping()
and then, I’ve got a message like below.(sorry for in korean)
TimeoutError Traceback (most recent call last)
C:\ProgramData\Anaconda3\envs\py36\lib\site-packages\urllib3\connection.py in _new_conn(self)
159 conn = connection.create_connection(
→ 160 (self._dns_host, self.port), self.timeout, **extra_kw)
161C:\ProgramData\Anaconda3\envs\py36\lib\site-packages\urllib3\util\connection.py in create_connection(address, timeout, source_address, socket_options)
79 if err is not None:
—> 80 raise err
81C:\ProgramData\Anaconda3\envs\py36\lib\site-packages\urllib3\util\connection.py in create_connection(address, timeout, source_address, socket_options)
69 sock.bind(source_address)
—> 70 sock.connect(sa)
71 return sockTimeoutError: [WinError 10060] 연결된 구성원으로부터 응답이 없어 연결하지 못했거나, 호스트로부터 응답이 없어 연결이 끊어졌습니다
During handling of the above exception, another exception occurred:
I’m not sure whether I can utilize “influxdbClient” or not when connect from local to remote host.
Could you help me to solve this problem?
I appreciate in advance.
