I am working with big data set in InfluxDB and need help with a query. I have a dataset where values remain constant for a period of time and then change. I want to filter the data to only return data with the timestamps where the value changes from the previous record.
Here’s an example of my dataset:
time value
2024-11-01T00:00:00Z 1
2024-11-01T01:00:00Z 1
2024-11-01T02:00:00Z 1
2024-11-01T03:00:00Z 1
2024-11-01T04:00:00Z 1
2024-11-01T05:00:00Z 5
2024-11-01T06:00:00Z 5
2024-11-01T07:00:00Z 5
2024-11-01T08:00:00Z 5
2024-11-01T09:00:00Z 5
2024-11-01T10:00:00Z 3
2024-11-01T11:00:00Z 3
2024-11-01T12:00:00Z 3
2024-11-01T13:00:00Z 3
2024-11-01T14:00:00Z 3
2024-11-01T15:00:00Z 3
2024-11-01T16:00:00Z 1
2024-11-01T17:00:00Z 1
2024-11-01T18:00:00Z 1
2024-11-01T19:00:00Z 1
Desired output:
time value
I have tried using the stateChangesOnly() function, but it only seems to work for predefined states like ok, warn, or crit.
Is there another function or method in Flux to achieve this for custom numerical values? Any advice or guidance would be greatly appreciated.
Thank you, have a nice day!
