How to efficiently get the timestamp of the first and last records in a table?
I have this simple flux code:
indices = from (bucket: "Desktop")
    |> range(start: 0)
    |> filter(fn: (r) => r._measurement == "Simulated" and r._field == "index" and r._value < 1000)
    |> keep(columns: ["fullname", "_time", "_value"])
    |> group()
time1 = indices
    |> min(column: "_time")
rstart = (time1 |> findColumn(fn: (key) => true, column: "_time"))[0]
indices produces a table of 1000 rows, and takes about 3 seconds on a data set of 40 million values.
time1 produces a table with 1 row and takes negligible time.
rstart produces a timestamp, and takes about 3 seconds to compute, even though it is operating on a table of only one row.
I can replace findColumn with findRecord, like this:
rstart = (time1 |> findRecord(fn: (key) => true, idx: 0))._time
This also takes about 3 seconds to run.
Ultimately I want to get the timestamps of the first and last records in the indices table. Is there a faster way to reference those, like a straight array reference, something like this?
rstart = indices[0]._time
rstop = indices[length(indices)]._time
@asthomas The following method takes advantage of some pushdown optimizations to ensure the query is as performant as it can be. Give it a try and see how it works:
indices = {
    _data = from(bucket: "Desktop")
        |> range(start: 0)
        |> filter(fn: (r) => r._measurement == "Simulated" and r._field == "index")
        |> limit(n: 1000)
    return union(tables:[
        _data |> first(),
        _data |> last(),
    ]) |> findColumn(fn: (key) => true, column: "_time")
// Returns a array with the first time as the first element and the
// last time as the second element
// Use an array reference to reference the timestamps
rstart = indices[0]
rstop = indices[1]
Thank you @scott. That saved one of the three expensive calls. As far as I can tell, the original filter for the indices is scanning the entire database. In a database of 40 million records, the filter on “index” takes about 3 seconds. Oddly, the findColumn call also takes about 3 seconds.
Still, your suggestion has eliminated one apparent scan of the database (I had 2 findColumn calls), so it reduces the total run time for this query by around 25-30%.
Now, how can I eliminate the time spent in findColumn?
