I am using sandbox. Due to some issue with MQTT, i am pushing my sensor date into influxdb using a python MQTT client script and Telegraph just does the default docker configuration like collection collection CPU usages etc.
I would like to create a dashboard so that the viewer can only visualize the sensor data and download the csv data if needed with out any access to modify the dashboard much like a pre created dashboard. How can i create it ?
