I visualized my real-time sensor data on InfluxGBCloud Data Explorer. Then I quired data for a third-party dashboard. But I do not get real-time data. There is 8 hour time difference between influxDBCloud data and my dashboard data. How to retrieve realtime data for a dashboard from InfluxDBCloud?
Thank you very much
Hello @Kasun_Jayasanka,
Welcome!
I think that depends on the third party dashboard solution you’re using.
I can help you with dashboard issues within InfluxDB Cloud, but for questions about another dashboard tool please go to the respective community.
What other dashboard tool are you using?
Thank you very much
I am using data visualization API of Autodesk platform services
Best regards
Kasun
