How to add values at each time point?
Hello everyone, I need help to display a single curve which, for each point, sums all the values of all the VMs.
(I upload an image of the whole text because I can’t display more than one image)
And here is my flux :
from(bucket: "GreenIT")
  |> filter(fn: (r) => r["_measurement"] == "ESX")
  |> filter(fn: (r) => r["_field"] == "CpuTotalGhz")
  |> yield(name: "mean")
I hope that I have been clear enough and that you understand. This is a problem I’ve been working on for some time and I still can’t find a solution. Thank you for the time you will spend helping me!
And sorry for my English if it’s that bad :slight_smile:
Hi Major,
Welcome to the community! So if I understand your problem correctly you should be able to sum each VM value using the following method
  |> group(columns: ["_time", "_measurement"])
  |> sum()
  |> group()
Essentially what we are doing is grouping each row by time and measurement. This will essentially put each time interval into there own table. so 12pm -> vm1(24), vm2(20), vm3(21).
Next, we perform a sum. this will perform a total of each row within a given table. In our case 12pm -> vm1 + vm2 +vm3. Now we perform an ungroup (group()) to combine the time grouped tables into one table.
@Jay_Clifford Thanks for your response. It helped me aggregating the bandwidth utilisation of all aggregated interfaces for a period of time. Really apprecitate. Thanks
