I have a customized server which needs INFLUXDB_ORG_ID as an environmental variable. However, according to the document (https://hub.docker.com/_/influxdb/), INFLUXDB_ORG_ID is exported as environmental variable after creating its docker image. I wonder if there is a way to retrieve this value and feed it to another server?
influxdb:
image: influxdb:latest
container_name: influxdb
restart: always
ports:
- "8086:8086"
volumes:
- /etc/localtime:/etc/localtime:ro
- influxdb-storage:/var/lib/influxdb2
- influxdb-config:/etc/influxdb2
environment:
- DOCKER_INFLUXDB_INIT_MODE=setup
- DOCKER_INFLUXDB_INIT_USERNAME=${INFLUXDB_INIT_USERNAME}
- DOCKER_INFLUXDB_INIT_PASSWORD=${INFLUXDB_INIT_PASSWORD}
- DOCKER_INFLUXDB_INIT_ORG=${INFLUXDB_INIT_ORG}
- DOCKER_INFLUXDB_INIT_RETENTION=365d
- DOCKER_INFLUXDB_INIT_ADMIN_TOKEN=${INFLUXDB_INIT_ADMIN_TOKEN}
- INFLUXDB_HTTP_HTTPS_ENABLED=true
- INFLUXDB_HTTP_HTTPS_CERTIFICATE=/etc/ssl/influxdb-selfsigned.crt
- INFLUXDB_HTTP_HTTPS_PRIVATE_KEY=/etc/ssl/influxdb-selfsigned.key
data-manager:
build: /data-manager
container_name: data-manager
depends_on:
- influxdb
ports:
- "5000:5000"
environment:
- INFLUXDB_ORG_ID=
