> select * from olx
time id name price title views
1638445619723411611 726553615 "Alex" 2000 SSD M2 Samsung 250Gb PRO 125
1638445652184178827 723134335 "Человек" 600 ОЗУ SK Hynix 4gb DDR-4 2666 81
1638445682003754288 728372625 "Alex" 500 Комутатор Ubiquiti UniFi Switch 8 (US-8) (все не рабочие) 233
1638445716856633795 723268384 "Человек" 4555 MIDI-клавиатура Novation LAUNCHKEY 49 407
1638445747457026240 723259840 "Alex" 1200 Графический планшет Wacom PTH-450 ( без пера ) 159
1638445784823900344 723260301 "Alex" 1200 Графический планшет Wacom PTK-440 ( без пера ) 129
1638445810871590032 723248702 "Alex" 5000 Ubiquiti Unifi USG-4-PRO 172
1638445835927006304 723134975 "Alex" 300 Точка доступа D-Link DWL-2600AP 121
Current request from grafana to influxdb:
SELECT views FROM olx WHERE id=723268384 ORDER BY time DESC;
It’s working, but for one advert. I need one request in db for array (id).
I don’t know how to create 1 request for the entire array, so as not to make one request for each id because the id often changes (ads are removed / added)
It’s my question
To filter multiple values you can just use OR, something like (id=1 OR id = 2)`, but since you don’t have a fixed set of values you can’t just put some static ids in there… This will be true for any system, not just InfluxDB.
you might get something that works using Grafana Template Variables as that will allow you to filter by a list, and use that filter wherever you want without actually writing fixed values in your query… if this is suitable I can’t tell, as it’s up to the use case
I don’t think so… if I understand it correctly no system will actually allow you to do so in a flexible way…
I will use an example to explain myself… let’s say you want to get a list of products…
| Category | Product |
| A | 1 |
| A | 2 |
| A | 3 |
| B | 4 |
you can logically write a query that does WHERE Product IN (1,2,3) to fetch the products, but it won’t “scale”, if any product gets moved/deleted/added you will have to keep editing it… which is just madness… what you want to do is use WHERE Category = 'A' as it will always work no matter what, without any need for editing unless the logic changes.
The problem is, you need an attribute to do so, in the case above I’ve used category, in your case I don’t any suitable attribute to filter those data…
if you actually explain what you want to achieve in the end I might understand something more about your requirement
without context, I can’t help you.
Also, the Grafana playground can’t be “saved” therefore I just see the standard “InfluxDB Group By Variable” sample…
are the names correct?
are you fetching at least one field? (without fields no data is returned)
which kind of editor are you using? the “normal” or “raw” one?
I suggest you create a new post, with proper info to explain your problem:
sample data
expected result
what you did so far and how It looks (queries/charts/etc…)
Otherwise, nobody will be able to help.
That question on StackOverflow is not that helpful either… what do you have in common with that?
Are you using mixed data sources? do you have unsorted data?
please create a new post with all the necessary info.
