I’m using the InfluxDB 2.0 UI. My data has several channels/series. When I make a query, the UI display all series together as follows:
Is it possible to display each chart in different panel like this?
If I create a dashboard, then create several cells/panels, I would need to set up a different query for each panel to achieve this. So my question is, can I still only make a single query, while the UI display series with each chart in its own panel?
