I have telegraf and influxdb installed on two computers, and Garfana dashboard on one only.
How can i pull data from the influxdb data source on the another system?
You can define multiple data sources in Grafana.
Simply define your two InfluxDB instances as two data sources with different
names, and you can then use those names instead of the standard “default” in
your queries.
Antony.
