hiw to backup and restore RETENTION POLICIES?
Hi @Hillbun_Ng ,
you can specify -rp in the backup and in the restore command
$ influxd backup -h
Creates a backup copy of specified InfluxDB OSS database(s) and saves the files in an Enterprise-compatible
format to PATH (directory where backups are saved).
Usage: influxd backup [options] PATH
-portable
Required to generate backup files in a portable format that can be restored to InfluxDB OSS or InfluxDB
Enterprise. Use unless the legacy backup is required.
-host <host:port>
InfluxDB OSS host to back up from. Optional. Defaults to 127.0.0.1:8088.
-db <name>
InfluxDB OSS database name to back up. Optional. If not specified, all databases are backed up when
using '-portable'.
-rp <name>
Retention policy to use for the backup. Optional. If not specified, all retention policies are used by
default.
-shard <id>
The identifier of the shard to back up. Optional. If specified, '-rp <rp_name>' is required.
-start <2015-12-24T08:12:23Z>
Include all points starting with specified timestamp (RFC3339 format).
Not compatible with '-since <timestamp>'.
-end <2015-12-24T08:12:23Z>
Exclude all points after timestamp (RFC3339 format).
-since <2015-12-24T08:12:23Z>
Create an incremental backup of all points after the timestamp (RFC3339 format). Optional.
Recommend using '-start <timestamp>' instead.
-skip-errors
Optional flag to continue backing up the remaining shards when the current shard fails to backup.
backup: flag: help requested
$ influxd restore -h
Uses backup copies from the specified PATH to restore databases or specific shards from InfluxDB OSS
or InfluxDB Enterprise to an InfluxDB OSS instance.
Usage: influxd restore -portable [options] PATH
Note: Restore using the '-portable' option consumes files in an improved Enterprise-compatible
format that includes a file manifest.
Options:
-portable
Required to activate the portable restore mode. If not specified, the legacy restore mode is used.
-host <host:port>
InfluxDB OSS host to connect to where the data will be restored. Defaults to '127.0.0.1:8088'.
-db <name>
Name of database to be restored from the backup (InfluxDB OSS or InfluxDB Enterprise)
-newdb <name>
Name of the InfluxDB OSS database into which the archived data will be imported on the target system.
Optional. If not given, then the value of '-db <db_name>' is used. The new database name must be unique
to the target system.
-rp <name>
Name of retention policy from the backup that will be restored. Optional.
Requires that '-db <db_name>' is specified.
-newrp <name>
Name of the retention policy to be created on the target system. Optional. Requires that '-rp <rp_name>'
is set. If not given, the '-rp <rp_name>' value is used.
-shard <id>
Identifier of the shard to be restored. Optional. If specified, then '-db <db_name>' and '-rp <rp_name>' are
required.
PATH
Path to directory containing the backup files.
restore: flag: help requested
